Förklaring på vignette
Startat av bellis, 11 September 2012 kl. 13:40
bellis
Jag ska ha en liten utställning på en skola i mina hemtrakter. Har en hel del viggar att visa.
Men har sökt efter en bra förklaring på svenska vad en vignette är. Utan att hitta en..
Nån som vet var det finns en att printa ut eller har förmågan att själv uttrycka sig i text som jag kan kopiera..
Tacksam för svar...
"A vignette is a short, well written sketch or descriptive scene. It does not have a plot which would make it a story, but it does reveal something about the the elements in it. It may reveal character, or mood or tone. It may have a theme or idea of its own that it wants to convey. It is the description of the scene or character that is important." (Hittat på nätet, går man vidare till legodelen hittade jag den här biten på LUGNET:
Q: What is a Vignette?
A: The word 'vignette' comes from the old French word 'vigne', which means vine. A vignette is the fancy, decorative design often found at the beginnings or ends of old books/manuscripts, describing the vine-like tendrils of the artwork or lettering used in decorative borders.
Over time, the word vignette also came to mean 'an unbordered picture', then as 'a short, literary sketch, or a short scene, as from a movie'.
In terms of LEGO, a vignette is basically a MOC built on a small base. How small? Well, see below.
To paraphrase Bruce Hietbrink in the first post to this newsgroup: "Small scenes built on small bases. They capture a slice of life, tell a small story in a scene, or provide a bit of humor. The small size encourages creativity, and allows fans with small collections to contribute. Quick to build, but long on thought, the emphasis with these models is FUN.
Another way of describing a vignette is that it is a MOC you would place on your desk or shelf for viewing. It is not really designed for play, nor the movement of the pieces/minifigs, as most other MOCs are.
Hämtat härifrån :http://news.lugnet.com/build/vignette/FAQ
Som kuriosa kan du ju nämna Joe vig:
http://news.lugnet.com/build/vignette/JoeVig
På Svenska skulle jag väl säga att en Vig är en liten frusen scen hämtat ur en historia eller livet själv som på ett finurligt sätt fångar en händelse,stämmning eller känsla på en väldigt liten yta.En skapelse inte ämnad för lek utan för skratt, igenkänning eller eftertanke.
bellis
Tack jag får försöka ta ut delar av olika texter. Bästa förklaringen är väl ändå:
Vi har ju vår egen tråd med film-viggar* också.
*Och bok-viggar, och tv-viggar...
